Erikclaw
.5" seems to be normal, but a whole inch off is kind of lame.
Tank is just mad because he doesnt have the power to turn his tires without 4.56s LOL j/k tank
Now I am getting an English education also. Thanks for this. I really appreciate to know all the money I spent on education and experiences I have had growing up was a waste and I could have just been educated on both from you. Thanks
I
I hated feeling the back of my F350 SRW with 18000# fifth wheel behind me when the wind is blowing. It will move the ass end of the truck any place it wants. I could feel the tires getting to the point of rolling over. Not a good feeling. Reason for the Dually.
Now tuners can change all of this, but we all know that tuners can mask the need for other things.
Just a difference of opinion on ideas is all it was too me. Some people like a dually for weight some dont, some like to have highway gears some dont.
Beating a car from 70 to 80 does not say a thing. That could be from a number of things. You were not in OD yet and did not need to downshift. He had to down shift 2 gears and was not in the power band when he down shifted, etc.
The reason you are having traction problems is not power, it is gears.
When you dont have enough gear you shock the drivetrain more, ever heard of flashing a converter. That is what you are doing.
Daily driving a tractor, well when you use these trucks for what they were built for I would blow your drivetrain up I bet in one trip to the beach. Try towing 18000#, 13.5' fiver up a LONG 7+% grade and see what the tranny temp does with 37's and 3.73 gears.
So you think you can take a 400 HP Porsche, I doubt it. There is a thing that is power to weight ratio. Hell I doubt 600 HP Superduty would take my non-stock 96 Impala that is more than 1500# heavier with a little more than 400 to the wheels. Too much weight and rolling resistance.
Been around long enough, more so racing gas engines. This is not my first go around with a Diesel, my last truck was an 04 F350 SRW that was not stock.
But stating that a 3/4 ton can handle a load better than a 450 is down right wrong. No matter if you use a steel rod for rear springs, 2 tires on the road is not going to handle the weight better than 4. Been on both sides and can vouch for that one. Remember my 350 SRW was not stock, including the suspension.
I read that wrong but it is still hard to believe when a rolling brick in the 8000# range and 600 HP can take a car that is 4000# and over 400 HP. SO he is in the 13 HP per # and the Benz is in the 10# per HP. Plus wind resistance at that speed in a rolling brick. Now I could believe it from a Dig for a quarter mile. But hell that Benz would most likely stay with or beat my moms 535i twin turbo that would hand my Impala its ass at pretty much any speed above 60, from a dig it is a different story, reason is weight and wind resistance. I doubt a 600 HP rolling brick could have stayed with either one.
For a lifted truck to overcome the wind resistance at that speed I would bet that he would have to have around 10.5-11 HP per # to overcome a car built to cruise at over 100. That would put him in the 6300-6600# range. A good comparison is look at cars running turbo or superchargers. They MPH way better for the same ET than these trucks. Weight and wind resistance kills the MPH.
I had the units backwards and cant edit the top one. It is # per HP.
So He is at 13#/HP and the Benz is in the 10#/HP.
Been on both forums long enough and by the join date not much shorter than you.
Anything is possible, my 04 was lifted 6" with springs I had made for the rear a little more spring rate than a 1 ton and ran the 2" 3/4 ton blocks with air bags. I never said that it could not be done, just said that 2 tires on the road is not as stable as 4 because I have done it, too much sidewall give in my opinion or at least with the pin weight of my Toyhauler. Even with a 7000# tow behind I could tell a difference with the dually. That was the reason I got a dually. Didnt like the wind moving me any more with the SRW. I dont think the lift has too much to do with it, if done right and not too tall, but the pin weight plays a major roll.
They were still there when I responded. Look another personal attack. Do you get something out of attempting to degrade people. I could care less what you think of me. Learned a long time ago that the only people that I give 2 ****s of what they think, Boss and family. The others you can live without.I purposefully deleted my entire response over an HOUR before what you responded to, and only MINUTES after submitting it for the sole purpose of avoiding any more communication with a dumbass.
Yes that is exactly what it is.Deference of opinion. Is that all...
If you are so good of a reader you would have read that I stated that I read that wrong. But I guess anyone else’s opinion don’t mean **** to you and everyone should take your word as gospel.Here we get our first glimpse into your lack of reading comprehension. The roll ons started at 70 to 80 and ended north of 130. Everyone other than you got it fine. At all times we must remain cognisant of your later SA comments about receiving an education about blah, blah and blah, so on and so forth while we read through blunder after blunder.
No I stated after that you either have more power or less weight in order to beat the cars that were stated you had. I could give too ****s on what cars you can beat. But stating you have 600 and not stating the truck is on the light side is leading people to think, hey I have upwards of 600 HP I can take a 400+ HP sports car when they are in an 8000# sled.Hmmm. So I guess chopping the throttle because the rear of the truck is in the next lane and those pesky black marks and blue smoke rolling out the wheel-wells is all the work of me pulling through the converter. Neverminding for a minute that I have my trans set to Lock the TCC the minute the truck hits 28mph and leave it that way....
Is it an opinion that I had traction issues with the Toyo OC AT's repeatedly, to the point of selling them for the MT ATZ's? Ah... no, lol. The truck repeatedly spun the tires with the converter locked in 3rd gear. 640+hp and those tires did not hook on my truck. Converter was locked up solid.
For anyone keeping score, that's error numero dos.
If you would have read further in my responses I stated that I never said that it cant be don’t, that it shouldn’t. Hell like I also stated I did it with my F350 SRW, just that I did not feel safe doing so.MontEagle is 6% and I have repeatedly pulled 17,000 up it with the cruise set at 65mph (55mph speed limit) and the trans temps were fine with the 4R.
Could have been anything, but saying that the 4.88’s cant handle weight is just wrong or the weight caused the failure. Hell they could have been out of oil, water intrusion, bad set up.Key takeaway..... it didn't make too much of a *** what gears I was running now did it? They both suffered the same fate. The 550 sooner probably due to the 3000 additional pounds of the truck itself.
Like I have stated a tuner, which you have more than that, masks the need for other things. Again difference of opinion. But large tires and stock gears with stock tranny’s have been blowing up for a while. Many people have done it. Maybe not you but I am sure you have heard or read that this guy but 40’s on his truck with 3.73 gears and wondered why he was going through transmissions or rear ends.Each of those trucks has towed as much as 23,000lbs, just not for any long duration at 7% or more, although towing 23,000lbs my truck with the 3.73's has been through the hills around my house a few times where the grades are 8%+. While the 550 has to downshift once or sometimes twice due to being tuned at ~300rwhp, my truck barels on at full speed with light throttle, 3.73 gears and all.
I bet your tranny is not stock, if it was it would toast, if it is stock Ford should take it and bronze it for display. What I have experienced with the tuning in these trucks is the TC locks at a certain MPH, which is set by gear size. You can not lock a TC earlier with 3.73’s than with 4.88’s without having some drawbacks. One which would be the turbo not staying lite. But you are correct that you an just downshift the truck and effectively get the same gearing I guess I don’t know the gear ratios of the 4R never had one so never really cared.Clearly the gearing is not the determinant of trans temp, nor what you can and cannot tow. In this case, one truck having a 4R100 with a large ford cooler and copius amounts of horsepower to use at will makes all the difference in both towing strength, and trans temp. 4.88 gears would be an unecessary hinderance in my truck, and 3.73's wouldn't make the trans in the 550 run any hotter, it would just run one gear lower than it does now and melt down the driveline just the same.
Again why is your experiences gospel and everyone elses is just BS. I don’t get it.Again.... we should clarify, this wasn't my nor your opinion.
Good for you it was stated earlier in the thread that you had 600HP.Who said my truck was 600.00hp? And mainly.... you talk in terms of hypotheticals, when my example was the C63 AMG benz that I DID kill..... twice....
Good for your truck. I have never esperienced a single tire holding weight better than duals. The only place I have been that I miss a SRW, the beach. Duals suck ass. My stock tires did not do to well at work in the mud the new ones I don’t have a problem. Of course I don’t have a problem in a 2wd Tacoma Prerunner either.Well..... you're wrong. Aside from the exceptionally better braking, my F-250 on 35 x 13.5 R18 Load Range E tires handles the loads BETTER than my F-550 on the stock sized and rated duals.
Well your experience with a SRW is exact opposite than mine. If it wasn’t do you think I would have got a payment, HELL NO!!In fact, as soon as I get away from the interstate I often drop the load at the office and switch back to my truck for the trip up through the hills to my house for STABILITY on the windy, hilly roads up there. I don't run the full trip with my truck as much anymore because of legality and the desire to lessen the amount of extra-curricular stress I put on it when I can.
It doesn’t surprise me. My brothers 06 F350 CCLB DRW is not much more than his old 06 F250 CCSB 4x4. But years make a huge difference. 05 they changed them and raised the capacity. My bothers 06 F250 was a lot more than my 04 F350 SRW.Something else to blow your mind...... the factory rated towing capacity listed in my owner's manual is HIGHER for a SRW truck of the exact same configuration as compared to that of a DRW. I personally think this due to added vehicle weight of the dual laden vehicle, but regardless I find it humurous in light of this topic.
Like stated in the thread you had 600HP in a truck that after weighing many of them, was in the 8000# range.First off..... seeing as how it already happened, it should have been a clue that you were in error. But.... by the numbers.... my truck at the time had just put down 644rwhp at ~70lbs of boost. At the time I ran the Benz I was running ~80lbs of boost because I just so happend to have been tuning the chargers when I ran across the Benz that day and didn't have time to mess with anything when I saw a chance to give him a run. However..... if we simply use the dyno-verified value of 644, that means that my 6800lb truck (with me in it) had a weight to power ratio (your choice, not mine) of 10.5lbs per Hp.
These two are the reason for my having stated that the majority of your assertions were incorrect, as these two are logically good.
I don’t think either one of us is running stock tires. I don’t know what comes on the F350 anymore have not looked. But I am not disagreeing with you on that statement. I had Toyo’s on my SRW and they did good. But the pin weight of 4500# cramming down on a tire in a turn. I will take my dually. It has not moved, I have to look at either the trailer in the mirror or the bushes most of the time to see if the wind is blowing. I don’t know what you tow but a 13.5’ 42’ long fifth wheel is a rolling brick that catches anything. Again our experiences are opposite.Two tires of equal performance, dimensional and strength characteristics would under normal circumstances be better than one for stability in terms of weight carrying capacity, however, since you do not have the constraint of tire spacing as you do with duals, with a SRW configuration you are free to run a MUCH.... MUCH higher capacity tire as a single than you could as a dual without spacers and such to keep them apart. In this reality, it is not hard to have a high quality single that outperforms a crappy little stock tire in a DRW configuration. The sidewall flex on our bone stock F-350 DRW is far greater than on my truck with the 35 x 13.5 R18 MT ATZ's. The dually gets thrown all around in the windy roads near my house and my truck is rock solid. I dread having to tow anything with that truck. It is squirrelly with far less weight on it than my truck will run without an issue at all.
Don’t disagree. My dually does not move side to side as bad as my SRW did.Fact. It's not my opinion. If you put a G-meter in the trucks you could record the additional lateral sway if a person felt so inclined.
I should have been a little clearer, my definition of a tractor is what we use to move rigs, a Semi. When I stated the super single I should have been more clear of what vehicle it was going on. The stock tires I had on my dually you are correct they sucked ass in the mud, snow, ice, etc. They were the continental tires and were off my truck in about 13000 miles because of it.And I can't help but laugh at the thought of grabbing a dually because you need better traction, lol. I'll try to remember that the next time I'm dragging my 550 up my driveway with the tractor because it can only rarely get a load of hay to the top without spinning down, whereas my 250 on 13.5" wide all terrains goes straight to the top in 2wd every....single....time...
Anyone that has EVER owned a dually KNOWS that they are PA....***ING....THETIC on snow, ice, mud, wet grass, fresh banana peels, so on and so forth...
Ummm...no...
Ive only felt that once. I had goodyear wranglers that were E rated put on my 3/4 ton chevy dmax and it was marshmallowy. Put Michelin LTX a/s on it in E rating and it was gone. Pulled 14k lb trailer and couldnt tell it was back there other than when I turned or saw it in the mirror changing lanes.
Im not saying yours didnt do that, just that IVE NEVER SEEN or FELT that. :shrug: I only tow about 50k miles a year though so I dont have a clue what Im talking about.
Then it is not an UMMM.....NO... then is it?
If you have never seen or felt it why did you stat it in your first sentence?
Couldnt tell it was back there, yep hear that all the time from people defending a SRW over a dually. Even friends do it towing around the same weight as I do till they tow with dually, guess what they go and buy a dually.
You must know a lot towing that much then.
