Daily Driver / Tow Pig Build....
mjonesjr
Salem, IN
I got the dang thing all together and on the road only to see that an inner axle seal is leaking. So I took it all apart again on Thursday, just to had to wait for Friday to get the seals. I got the Spicer 52148 seals. They are an upgraded seal over the factory seals.
Hopefully I will have the truck put back together tomorrow and back on the road. I've got an appointment on Monday to have a new headliner put in the truck. I can't stand the sagging headliner that the OBS trucks are known for.
mjonesjr
Salem, IN
Got the new inner axle seals Friday night, but couldn't do anything with the until today.
The difference in the new seal and the old seal can be seen right off the bat.
To get the newer seal to work in a '93-'97 Dana 60, you have to do a little modification to the seal itself. The '98-'07 Dana 60's have a larger machined area where the axle slides into the seal than the '93-'97 version. To get it to fit, you have to do a little grinding on the steel lip that sticks out of the inner portion of the seal. Once it is off, the seal will go in the axle like the original seal. Doing this grinding still makes this seal a MUCH better seal than the original.
This grinding will have to be done even if you get the National 710530 as the Spicer seal is made by the same factory and is the exact same seal.
The truck is all back together and on the road again. It is setting at the upholstery shop waiting for its new headliner to be installed tomorrow.
mjonesjr
Salem, IN
The new headliner is awesome. It looks like it did from the factory. They guy who did it said that he took the headliner board out through the doors. Everything I read online said the board had to go out through the rear window; I guess not.
I got the front axle and engine cross member all painted up and looking good.
mjonesjr
Salem, IN
So I crawled under my truck earlier this week to find that my rear diff cover had rotted allowing gear oil to seep through the cover. At one place on the cover, the steel was so week that you could move it with your finger. It probably didn't help the cover when the rear tank was leaking on it.
So instead of getting a replacement ($50) or an aftermarket ($275), I went with a '08-'11 F-250 & F-350 aluminum diff cover. I picked it up at the local Ford dealer for $79 with a small bottle of Motorcraft friction modifier. The part number for the diff cover is 8C3Z-4033-A. You will have to get new hardware to mount the diff cover as the aluminum one is thicker than the OEM cover. Since they are exposed to the elements, I went with 5/16-18 x 1.5" stainless, stainless flat washer, and a stainless lock washer.
Here is a comparison of the factory cover that came off my truck and the OEM '08-'11 Super Duty cover.
The Super Duty cover is installed with black Form-a-Gasket only. I thought since my housing was an older housing, I would be double safe than sorry. I used the black Form-a-gasket along with a Felpro Sterling 10.25 gasket. I put the Form-a-Gasket on the cover first and the gasket on afterwards.
Got the cover installed and the bolts torqued to 36 ft. lbs. and the fluid installed. I went with 75w90 full synthetic fluid with the 4 oz. of friction modifier.
CamTom12
Huntsville, AL
The truck looks great!
I wish I'd posted in time to recommend you had some dynamat put on the roof while you had the headliner out. I haven't done it yet but I heard it's a pretty decent difference in highway noise.
Amazing work!
mjonesjr
Salem, IN
Amazing work!
I might have to eventually pull the headliner back out and do that. Thanks.
mjonesjr
Salem, IN
I got it all at Tractor Supply. All the stainless hardware (bolts, washers, and lock washers) cost me $15.
mjonesjr
Salem, IN
I got the old gauges uninstalled and the ScanGauge installed. I am going to wait till spring to paint the gauge pod to match the interior.
I have to wait for my new boost PSI and fuel PSI sensors to arrive. The ones I got were bad. Hopefully they will be here this week so I can get the full function of this thing going.
Before:
After:
mjonesjr
Salem, IN
Nothing, but I did sell them.
With the added ability of the ScanGauge, I was able to also sell my AE software as well.
