Dyno proven honey badger jr review
Six_Sloww
Southeast MI
Depends on the design. I know my old s300 up pipes would never clear a race cover, no way in hell. Or even a standard cover s400 for that matter.
04cr450
harford county, maryland
Gotcha^. Mpd up pipes might not then.. ced pipes might though as the turbo sits higher in the valley compared to mpd's. I only say that as the downpipe just clears the back 10mm hex head bolt on the intake manifold with mpds.
Six_Sloww
Southeast MI
My issue was the support bracket, it was really close to the compressor housing. That was with Matt's s300 pipes.
Swink, you're adding a gate anyway aren't you? Won't you need to add a provision or get pipes that have a provision anyway?
swinky
Eastern, Nc
Well mine broke off so i might be able to fit a 400 now.....
swinky
Eastern, Nc
What's your dyno numbers with current set up
Probably 600 on fuel and 675ish on spray with the 190s.
Fixed it for ya. Don't need a dyno when he's got lots of track time
Thanks bud. Might strap her on at rudys and see if it can break 750 for the hell of it. Probably not though.
Six_Sloww
Southeast MI
Dyno's are fun and you can still make a competition out of them between friends if you all run on the same one.. But there's too many variables between different Dyno's. Compared to running on the track IMO.
