White_monster
Very constructive mike.
I still think cooling the actuator is a smart choice. That piece gets screaming hot, I touched it by accident and it wasn't fun. Maybe a small bracket on the firewall for the reservoir would be clean. Be nice to ditch the big ugly bracket for all of this stuff and let the engine be seen.
the actautor has its own coolant line running to it like the cooler. that small reservoir are looped but i dont see a prblem with looping it to the top of the degas bottle where there is nothing on it besides a plug.
Has anyone actually measured fuel temp on return? Stock I saw around the 120 mark. When I did my fuel bowl delete and entire lp system I now see 60 degrees. Ford most likely added the cooler to cool the fuel before it entered the fuel bowl and mixed with the fuel from the tank. With the constant cycling in stock form the heat would rise. I bet taking the cooler out if you have a fuel bowl delete would have zero affect on the fuel temps, the tank is large and the fuel will be cool enough to keep temps down. Stock system is a different matter.
Yes it does have its own line. And it goes from the actuator to the reservoir then to the cooler then out to the front of the truck if you follow the lines. Deleting the cooler is easy, heck taking it all out is easy. It's wether risking that actuator is something you want to do, it's not cheap to replace.
so im not allowed to have fun at BFT's expense?
When I check last year it was $750can so about $500us I'd say. For the little bit of work to keep it cooled I think it's worth it.
that reservoir doesnt carry enough to cool the actuator and the fuel. im sure its just a feed and return? if thats the case you can loop it like mentioned before.
That little resrvoir and front cooler is what holds the coolent for that system nothing else
What circulates the coolant if it's closed off from the engine cooing system?
