White_monster
Thank you. Someone else that's studied the system.
It has its own pump
It has its own pump
it does? where is the pump?
Hard to see in the middle of your fan shroud where it bolts together on the driver side..
easier to see if your under the truck.. ita electeic ofcourse
With higher temps but yes you could do that.
The factory pump doesn't even turn on until the inlet fuel temps hit 160 so basically that coolant is stagnent most of the time unless your.towing heavy with low fuel levels
learn something new everyday i guess. where does the coolant line to the actuator go to?
Also forgot to mentiom for all you twin turbo guys who dont want to pull your turbos... The lines on the motor for your supply after the fuel bowl is 3/8s and also its 3/8s to the fuel cooler. so you can use tubing cutter and tube fitting to do this.... Just cleaner the other way...
