head removal question ASAP
89 Stroker
Southern Cali
decided to cut the cross member, deff don't have the funds right now for another motor so i am stuck
pulling the motor out (for me) is 10X harder then cutting and re-welding a cross member
7.3psd97444
Indiana
question - are the intake and exhaust valves the same ?
NO
Are you serious...
You GOTTA know someone with a motor jack....
Ad8 PRODIGY
Orange County, NY
Could you please elaborate on why you feel it would be easier to cut the cross member instead if pulling it?
Laying on your back, under the truck, in an awkward position to replace the piston.. sounds like fun.
Pull the engine..
89 Stroker
Southern Cali
Pull the engine..
cause that's what i do, cut - fabricate - and weld, thank god its lifted, i can sit pretty nice under there
Powerstroke Cowboy
Montana
The exhaust valves and intake valves are different...
Pull the engine would be less work. Do yo up plan on keeping the pickup for life?? I would never buy a pickup that has had the cross member cut off the welded back on.. Even if it was done good. Just for the fact it would tell me the owner or who ever worked on it did not really care...
bluedge8
Champlin MN
whats a better option, getting a motor from a junkyard or online/craigslist?
We are at the point that he is going to do his own thing, I hope it works out for him but fear it wont. Good luck, you will need it.
neverkickn
AR
If you are such a good fabricator why don't you just weld up a gantry and hook a damn chain hoist to it. I kinda feel bad for you in a way because you are going the hard route here on a relatively simple procedure.
