My 6.0 build
smokinstroker
Texas
i believe mpd made them at one point. rcd also sells a full relocation kit.
if you have any questions feel free to shoot me a message.
smokinstroker
Texas
Is that kit just for the oil filter or for both the oil and fuel filters?
RCD's kit is just oil. The fuel bowl is attached to the oil bowl. when you delete oil the fuel is gone to. you will need to run your fuel feed straight to your "t" or "y" for your heads
Pizza pig
MD
Just buying a 6.4 housing doesn't mean it magically transforms into a fuel bowl delete tyler LOL you need to make fuel system modifications, its very easy though.
Hellen Keller sent this?
Josh@DirtyDiesels
PA
If I'm deleting the fuel bowl and moving the oil filter it will be when I do an external oil cooler setup.... RCD kit is sweet but I don't "need" it so I'd rather wait and do an external cooler setup instead
powerstrokedkid87
New Jersey
in the process of doing this as well......going to clean up everything so much better!
Josh@DirtyDiesels
PA
Hoodstack is off the truck for the winter. Have a few little power adders hopefully going on before our dyno day next month. Hopefully we see some good numbers finally!!
Josh@DirtyDiesels
PA
your painter did a good job matching the paint
yep! The color matches perfectly. Just looks a little off in the pic cause the hood is freshly buffed and the truck is filthy... I still need to wetsand and buff again. It has some dust spots and one run on it :( but can't complain when it was done for next to nothing!
