Beast6.0
- Joined
- Jan 2, 2012
- Messages
- 51
- Reaction score
- 0
Glad to hear they didn't leave you hanging, if you only need the boost to come on a couple hundred rpm sooner and you where happy with the 64's performance, maybe go with a 64/68/70. The smaller turbine wheel should give you a bit quicker spool, and they seem to be handling back pressure fine. As far as the Precision, I know a few gassers that have good luck with them, but not sure if they'll like the higher boost/drive pressures that the diesels run at. Might work fine though. You should drop that question over on CompD in the Supercharger/Turbocharger section in the Competition build area. Alot of good guys with lots of knowledge over there, definitely someone could give you a comparison of the two. Good luck with whatever you end up going back with
