Hay there guys I am finally back on here after a pretty long break from everything. I got a new job and have been working 70+ hours a week for a good bit now so there was absolutely no time to come on here and keep up with everything. Filling you in where things have left off....Truck ran great upon first putting the turbos and nozzles on. I went out Friday finally to mess with the wastegate settings and after a hard run on the highway, my motor developed a tick. Not a knock, but just a louder ticking noise. Yesterday I pulled it all apart looking for a broken rocker or something and did see a rocker that was rubbing on the side of the fuel rail mount. I am not sure how that would happen, but somehow the bolt must have come loose in there and then the rocker was moving around a bit. The rocker was not broken nor where any others. The one thing that I did see is that on the rocker that was rubbing on the fuel rail mount there was no oiling holes in the tip of the rocker at all like all the others. I know that last winter when we did my intial build, we did replace a few rockers that were tight and this may have been the ones that we put in and never saw that they didn't have oiling holes. But anyhow... I have all new rockers coming for the truck and was really wishing that elite would have theirs done so I could drop them in and not worry about the rocker issues anymore, but I don't see that happening. I am just going to replace all the rockers with new OEM units and put the truck back together and hope the ticking is gone. One other thing that I noticed as well is that I wasn't building much boost with the kit either. The most I hit was 44 psi so far. And when it hit 44 psi I almost think that the gate opened up all the way because it was like it lost power. I have 1 bar of spring in the Tial gate right now with the controller turned 1 3/4 turns from counter clockwise. Is there something that I need to change here? What is the spring rate the rest of you guys are running for the gates? In case it matters, I am gating into the atmo and currently have just the H&S tunes that I am running.
