Need help with Fuel system
SSpeeDEMONSS
6mi from the beach, SoCal
I built my own fuel system a few years ago. Airdog 150 feeding the front and rear of the heads. Only thing stock is the tank. If I was going to keep the truck it would get a sump, a fuelab, and a regulator. Though it worked great and no problems with the airdog.
Garrett
Probably getting paid at work to post this from my D1
Oregon
LOLLOLSo where does the air go once in the regulator? I think you should do some more reaserch maybe even give jake a call and ask him if his kit removes air.
Another question to so when running a FASs or AD why would they offer air Seperation if it all happens at the regulator?
Spindrift
Austin, TX
I'd like to do a RR first and then see if my factory pump can keep up. Can anyone see a downside to this approach?
windrunner408
A RR kit doesnt remove any air in the fuel. It only provides an alternate path for the majority of the air to go. With the stock setup, the fuel dead heads at the back of the motor and ALL of the air in the fuel (with out an AD or FASS unit) is forced through the injectors. However with a RR kit, you have a 3/8in line that the fuel passes through and backs up at the regulator until it reaches a certain pressure and the remainder continues on to the tank along with whatever air is in the fuel and only a portion of air (compared to when stock) going through the injectors. Its not a 100% air removal like the FASS or AD units.
Oregon
Ok....... With out a FASS or AD where does the air go? It's not being removed! All I'm trying to say is jakes system does not remove air! It your wanting to remove air it needs to be before it even makes it to the heads. Not at the return. I dont know about anyone else but air being removed at the regulator is halarious anyone thinks that. WHERE DOES IT GO? And if you have that much air in a system you have a problem. I'm a firm believe that removing air is not that big of a deal. If you have the AD or FASS, great use it. You don't have to have it.
Derek@Vision Diesel
Canby, OR
It goes right back to the tank... rather than being trapped in the heads. On a SD they dont have a return system stock, any fuel that makes it into the heads HAS to be used by the injectors... thats just how it is. Little different setup than your truck, you had a return sysem even stock.
But i agree with everything you said, it doesnt remove air. It redirects it
Oregon
And I agree to. I know that with the SD that use the fuel supplied and not retuned like the obs. All I'm trying to say is if you have air it needs to be removed before even makin it to the heads. And air does not get removed at the return on any system! And jakes system does not remove air. Is jakes system bad because it doesn't remove air? Absolutely not! Jakes system is amazing but removing air is not an option with his system.
windrunner408
It does not remove air. It redirects it
:whs: Yes to all of this. Finally someone making sense on here.
faster6.0
That's why our RR kit maintains the factory fuel bowl as it still utilizes the air purge hole.
05wh250
hendersonville, nc
has anyone ran an a1000 with the stock regulator? i got dozers rr but the cabs coming off in a couple months, and heard its a pain to put in with the cab on.
MorganY
college station, tx
its a pain, but is doable. it took me 6.5hrs with the banjos cab on, up pipes loose..if I could do it again I would use the 90 fittings
