Craig have you guys Dyno tested your manifolds? Just curious.
Maybe Dozer will give you a set of his epic log style manifolds......
I bet His work just as good as the ones you "gave" me
Just a heads up , did a before and after of steed speed manifolds, the truck went from 743 to 672 ... Huge loss and spoolup as well as back pressure got worse. They will be coming off immediately. Graph to follow when I get to a computer.
I've tested them on my single kits when I first made them on my truck and single kits
We did have them flow tested and flowed 15% over stock
I personally feel that the 2.5 outlet is the biggest issue I think they loose velocity in that area and then a forced to cram back down in a smaller pipe.
:whs: Thanks for clearing up what I was trying to say.The manifolds were bolted on with the uppipes and no changes were made to tuning or the Wastegates.
The runs were made to compare
Then the gates were tuned back in to.desired back.pressure and they also loaded a different tune and they were still unable to make the same.power as the 6.0 manifolds even with changes. They were able to get over 700 but not close to.where it was.
