6.7L WITH 6R140 TRANSMISSION—2-3 SHIFT FLARE TSB 11-7-10
AND/OR MIL ON WITH DTC P0733 AND/OR DELAYED
REVERSE ENGAGEMENT—BUILT ON OR BEFORE
4/11/2011
FORD:
2011 F-Super Duty
ISSUE NOTE
Some 2011 F-Super Duty vehicles equipped with PLEASE ADVISE THE CUSTOMER THAT THIS
6.7L engines and 6R140 transmission may exhibit a VEHICLE IS EQUIPPED WITH AN ADAPTIVE
2-3 shift flare and/or malfunction indicator light (MIL) TRANSMISSION SHIFT STRATEGY WHICH
on with diagnostic trouble code (DTC) P0733 and/or ALLOWS THE VEHICLE’S COMPUTER TO LEARN
delayed reverse engagement, with a build date on THE TRANSMISSION’S UNIQUE PARAMETERS
or before 4/11/2011. Symptoms may be more AND IMPROVE SHIFT QUALITY. WHEN THE
evident or seem worse after an extended soak. ADAPTIVE STRATEGY IS RESET, THE
COMPUTER WILL BEGIN A RE-LEARNING
ACTION PROCESS. THIS RE-LEARNING PROCESS MAY
Follow the Service Procedure steps to correct the RESULT IN FIRMER THAN NORMAL UPSHIFTS
condition. AND DOWNSHIFTS FOR SEVERAL DAYS.
SERVICE PROCEDURE PART NUMBER PART NAME
1. Inspect vehicle build date. BC3Z-7G383-K Solenoid-Band Number 2
BC3Z-7G383-L Solenoid-Band Number 3
a. If vehicle build date is on or before BC3Z-7G383-M Solenoid-Band Number 4
11/19/2010, proceed to Step 2 BC3Z-7G383-N Solenoid-Band Number 5
b. If vehicle build date is between 11/20/2010 WARRANTY STATUS: Eligible Under Provisions Of
and 4/11/2011, solenoid replacement is not
New Vehicle Limited
necessary, proceed to Step 3.
Warranty Coverage
2. Replace the three (3) normally high solenoids. IMPORTANT: Warranty
Refer to the Workshop Manual (WSM), Section coverage limits/policies are
307-01B. Proceed to Step 3. not altered by a TSB.
Warranty coverage limits
a. Remove solenoids in-vehicle, identify the are determined by the
service band required for LPC, C35R/SSB, identified causal part.
C456/SSE solenoids. Do not remove the
main control. OPERATION DESCRIPTION TIME
110710A 2011 F-Super Duty 6.7L: 0.6 Hr.
3. Reprogram the powertrain control module Check DTCs, Reprogram
(PCM) and the transmission control module The PCM And TCM (Do
(TCM) to the latest calibration using IDS Not Use With Any Other
release 73.02 and higher. This new calibration Labor operations)
is not included in the VCM 2011.5 DVD.
Calibration files may also be obtained at
www.motorcraft.com.
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do
the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper
vehicle service. The procedures should not be performed by “do-it-yourselfers”. Do not assume that a condition described affects your car or truck. Contact a
Ford or Lincoln dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine
Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article.The information in this Technical Service Bulletin (TSB) was
current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates.The most recent information is available
through Ford Motor Company’s on-line technical resources.
Copyright ã 2011 Ford Motor Company Online Publication Date July 8, 2011 PAGE 1
TSB 11-7-10 (Continued)
110710B 2011 F-Super Duty 6.7L: 2.0 Hrs.
Check DTCs, Replace
Three Shift Solenoids,
Reprogram The PCM And
TCM (Do Not Use With
Any Other Labor
operations)
DEALER CODING
CONDITION
BASIC PART NO. CODE
RECAL 04
PAGE
