smokinstroker
Teamwork! Hahaha
So Lance just split a boot trying to log for me. LOL
It was making like 26 psi max. Matt played with some stuff and its holding 30.
Thats exactly what the MTW is doing on my truck. I'll be watching this thread for your final solution. I'm running a bat-mo-wheel what about you?
Is your mtw a 68 pmax?
I have the duty cycle set to default to 30% once the EBP sensor gets pissed off with the drive pressure and gives up. There was no point in running inferred EBP as the truck runs beautifully as is. It will be a good comparsion if the regular wheel makes more boost than the batmo....... with the EBP being exactly the same before and after, it will be a good comparsion on how the compressor flows.
Being devil's advocate here - and I really don't know how this all plays out in the end but - in order to know which compressor wheel is truly flowing more under the same circumstances don't you need to know more about the ambient and intake air temperatures? If the cast wheel makes more boost, but is noticeably hotter - is it really more air? I know I'd like some more info about the whole turbo wheel comparison. There is a whole host of different opinions - some swear by the new wheels - some swear at the new wheels - some just want to make educated choices - and even more want to just follow the new fad.
I purchased a batmo equipped charger based on the recommendations from a very well known shop that it would broaden my power curve and add more air at lower turbo shaft speeds (which would be beneficial for lowering smoke and towing at higher power with lower EGTs). I don't know what the outcome of my experiment into this controversial wheel will be - I know I don't expect it to add to my peak power - but I do hope that it performs well at the task I need it to - if it doesn't I'll chalk it up as a learning experience and make sure to tell everyone when I switch to a billet wheel of another manufacturer.
