unhooking the regulator should make the cp3 to go to full fuel, know when i was testing one that even unplugged the control from stock pump was enough to make it drive somewhat smooth ect, only thing i noticed was after a hot restart the truck would want to make 10k pressure instantly and the injectors rattled, i dont remember a surge however.
Where did you get the cp3? Could it be bad? Or wired wrong?
..any reason to not run the truck (for a short test) w/o the belt installed to confirm this..? assuming the batteries are good...shouldn't hurt anything for a short run.
I suppose I could try that. If anything it'll give me a head start to pull the cp3 out. LOL
Think abouy going to a dual k16 setup?
YouTube Video |
I'm running 60% nozzles, twin K16s...and have np holding RP.
based on the sound your pump is making..and lack of RP...I think you need to check LP fuel pressure...fuel quality..and then when your sure you don't have any trash in the system..put another pump on.
Yes unplugged is full fuel
