5r110 Limits LMAO
Marty
Elkton, MD
That statement is not 100% accurate. What Brian says is he does not recommend the increased capacity pans if you do nothing with the cooling system. His claim is that once the fluid gets hot during a hard run the stock system takes too long for the temps to drop back to normal. If you add additional cooling capacity they work well according to Brian. I do not agree with his assessment of the stock system being inadequate on the 5r's as I think his opinion is based on the clearly inadequate 4r cooling system. My 5r has run consistently 10-20* cooler with a Mag pan even when I towed my 15k boat.
And to the original question it's not so much the HP as the transmission tune. I would bet a John Woods tuned trans would handle 550-600hp 2 times as long as some of those other "tuners" trans strategy would handle 450hp.
To add to that, he said the deeper pan created suction issues for the pickup tube especially on trucks that heave the frontend to the sky.... ie: lightnings with bts trans in them.
Just can't find good help these days. LOL
Soooooo true.
java
I think i might order gogo's solenoid, i have eliets ssx and some 190/100's coming and i would prefer my tranny to last a while haha
strokin6L
Springville NY
suncoast's dd solenoid absolutly sucks. I've ran both the suncoast and gogo's dd solenoid. Dougs dd solenoid is waaaaay better than the suncoast piece of chit.
Mdub707
Mohawk NY
Calculator puts my truck at 675 when sprayin with my 225's and stock trans....... Pretty good tuning and its NOT john woods.
What cab/bed config? You have a lighter truck don't you? Power is one part of this, but when talking about trans life it's clearly going to hold up better pushing a lighter truck down the track too. Obviously...
so the only reason to do this with 190's instead of a smaller injector would be the potential to add that extra fuel back if wanted with a bigger turbo??
Pretty much. My whole point was some guys don't ever plan on going bigger than a p-max yet still put 190's in, it's just too much fuel for a p-max. What is the point of going that large on the injector if you're pulling fuel in every tune to keep it clean anyways? Not aimed at anyone in particular, but we all see this on the boards a lot.
I have heard the same thing, I will be buying the GoGo unit when the weather warms up.
imelmo
Because you can always spray it at the track with an all-out tune, and pull the fuel out on a daily driving tune.
Mdub707
Mohawk NY
How much spray do you think is needed to clean up a 190/100 with a powermax? That's a lot of fuel for that turbo it seems...
imelmo
Not sure. I'm about to try it with some 290's though. LOL
I'm hoping the turbo is as tough as the stocker or a 38r.
