Project Wheels Up
I removed the wiring for the fuel bowl heater, IAH relay, water in fuel sensor, ebpv pedestal plug, ebp sensor, and relocated the GPR and starter solenoid. Now it's just the bare minimum wiring needed.
No Jason I'm going as far as possible with this system first. Besides, the 3,000 lb diet will be more than enough of an improvement over my previous times. Even if I stayed at 600hp. The boost in HP from those agricultural parts may actually cause poo to come out if I'm not aclaimated first. LOL
Thats gonna look clean! What ag parts are you talking about?
Chvyrkr
Pretty sure Jason was talking about the ether injection kits that can be triggered from the drivers seat, that are available at any ag supply outfit. Basing that assumption on previous conversations with him, and your picture lacking a GPR.
But... A mech injected 4000# pickup with a 7.3 would be a baaaad mofo!
Hotrodtractor
Mingo, Ohio
You are not picking up what I am putting down.
vanderchevy18
Benton, Ks.
You know, the truck itself isn't that expensive. Well, not by truck standards anyway. It's all the little crap that adds up. I spent $200 on switches, brake line fittings, wiring, etc. She'll be sexy when I'm done though!
JoeDaddy
Gridley Ks
Did you find a set of front wheels?
BTW the frame looks AMAZING!
And Rad in the rear. Coolant on the track sucks....it sucks a whole lot less when you dont drive through it.
vanderchevy18
Benton, Ks.
Well I'm running out of time so I am trying to just get it running right now. Finally had a chance to work on it this weekend. We're getting quite a bit done but it's a long ways from being ready. Looks like it'll just be a rat rod for the moment.
paint has nothing to do with performance! good luck man! get at it!!!
