6.7 Twin Turbo Setup
Pizza pig
In the Brig (Banned)
MD
It's obvious too, when you drive the two back to back. The 5r in the 6.4 downshifting and part throttle manners are worlds better. Only time I feel like my 5r in my 6.0 knows what to do is from a dig full throttle.
whose tuning your truck?
swinky
Eastern, Nc
Exactly! From a 50-70 roll this thing has never been right. Fine from a dig.
You don't have a Tcm.
Gayy. I thought a used 6.4 trans would hold in my torqueless 6.0 for sure.
Sent from my HTC One using Tapatalk
Jesse_01
Prince George, BC. Canada
I am finding I am driving in tow haul all the time to keep the rpms up. I am only running 325/65r18. The 37" + guys must really noticing it. On the highway I have no need for the 6th gear.
Sent from my SM-N900W8 using Tapatalk
Dan
Fort McMurray AB Canada
Old engine spun mains, new shortblock is being built by tadd should be ready in about 5 more weeks, I'm super anxious to get er back together!! Then when tadd has girdle and billet main caps, I'll be looking to go that route!
Craig@MFI
Spun the mains? That's really odd seeing as many others have not had this problem? Maybe you should look into a oil cooler delete this time to keep those temps down seeing as if the block was filled it most likely blocked the coolant supply to the oil cooler and was only getting coolant pressure and no flow to it
Sent from my SAMSUNG-SM-N900A using Tapatalk
Dan
Sign me up Craig! Haha
Oil temps were hot, and likely a contributing factor...
I'll pm you regarding that block off plate you have available!
bricewise
Glad your pushing the boundaries for everyone else. It makes our lives cheaper and easier. However I'd be curious what made you land on needing a girdle?
Dan
There's other guys out there pushing the limits as well and having very good luck!!!
Crank flex, block flex... Tie up the loose ends with a girdle... Rigidity is fairly key... And yeah I know, cross drilled 6 bolt mains with that graphite iron block should help things, but put me behind the wheel 6th gear on spray with overly hot oil... It's a party for everyone!
Like I say you can't build a skyscraper on a cinder block!
4EverBoosted1
Are you sticking with your turbo setup? making any changes to the performance parts at all?
Fast-6.0
Alamosa, CO
When I fill a 6.7 block I don't restrict the water to the oil cooler. Especially when I know they will be running a factory oil cooler. That would just be foolish!
The oil temps may have been high, and yes I do agree that the oem oil cooler is lacking, but the main bearing furthest from the oil supply showed no signs of lack of lubrication.
I also confirmed the failure with two race shops and the consensus was crank flex.
