swinky
Yeah and a 6.4 is like 1150.
Soo is there an advantage in tuning?
You don't have a Tcm.
It's obvious too, when you drive the two back to back. The 5r in the 6.4 downshifting and part throttle manners are worlds better. Only time I feel like my 5r in my 6.0 knows what to do is from a dig full throttle.
How much of a difference would going from 3.31 to 3.73 be on life of tranny?
Sent from my SM-N900W8 using Tapatalk
3.55's and 38's = 1550 RPM @ 75 MPH
Ahhh I wondered how long it would be before someone made a girdle.
Glad your pushing the boundaries for everyone else. It makes our lives cheaper and easier. However I'd be curious what made you land on needing a girdle?
There's other guys out there pushing the limits as well and having very good luck!!!
Crank flex, block flex... Tie up the loose ends with a girdle... Rigidity is fairly key... And yeah I know, cross drilled 6 bolt mains with that graphite iron block should help things, but put me behind the wheel 6th gear on spray with overly hot oil... It's a party for everyone!
Like I say you can't build a skyscraper on a cinder block!
Spun the mains? That's really odd seeing as many others have not had this problem? Maybe you should look into a oil cooler delete this time to keep those temps down seeing as if the block was filled it most likely blocked the coolant supply to the oil cooler and was only getting coolant pressure and no flow to it
Sent from my SAMSUNG-SM-N900A using Tapatalk
