jdgleason
I wonder if there's barometric pressure and a nice correction factor
After fajita night, barometric pressure is pretty high in my experience with butt dynos.
I don't see how making it bigger will help anyway
So many ways that can be taken.:lookaround: For all of you guys praising the larger outlet design, perhaps you should consider full 3" up pipes with some custom 3" outlet manifolds, and turbine inlet porting to prove velicity means nothing for spooling a turbo. You can report your commando calibrated butt dyno results here!!:naughty:
Leen when are you sending the new manifolds to Elite for testing?
Yes. They are at the ceramic coater right now and I expect them to ship this week. I'm also trying to set up a test at another shop that has an in house engine dyno which would be a more convenient and accurate way to test..
I wasn't praising anything, just curious cause the other vendor building up-pipes claimed they needed to be port matched.
I'd love to see results on an engine dyno.
I am currently in the limbo with a set we just put on. I currently have the cab in limbo as well. The 2.5 up pipes are not working well with the cab and down pipe. We have the latest design second only to the one leen is sending out to be tested now. I have done some comparison to the 6.0 manifolds that I have sitting here. Really the manifold volume itself is not that much different from each other. But when you figure the up-pipe volume difference between two inch and two and a half over the length there is a huge difference. We have the same 6.4 litre air pump filling the manifolds and up-pipes. No matter what one tries, it takes longer to fill the the big up-pipes. There is roughly 155% more volume in the 2.5"from version over the 2".
I am currently contemplating the outcome of scrapping the 2.5" pipes and building a custom 2" from some old factory pipes with the v-band off of the 2.5".
There is no reason that the steed speed design is that terrible by principle, they fix the problems that a log style manifold has by design, IE: by directing flow in the direction of the outlet smoothly instead of going straight out and slamming a 90° wall. Even reverting backwards in some cases until the cylinder ahead of it forces it back out.
Personally I would like to see the same manifold dynoed with 2" pipes. Even though it is a little incorrect to the original purpose of the 2.5" outlet.
No worries. I wasn't singling anyone out. port matching is a good thing, but as I'm sure you know, there are many other things that come into play.
If you have a power loss or no gain wonder how 6.0 liter manifolds would perform by comparison...
I have the two inch up pipes on my truck with the manifolds. I really think the 2.5" outlet on the manifold and the large volume inside the steed speeds is slowing down the velocity like everyone else.
