why do you need a regulator on the fuel pump?
The kits are designed similar to factory and when they came out that was sufficent. Things are changing in terms of performance and now we have found an issue. We need to possibly regulate the supply due to too much volume of fuel. I'll know more once I do my tests.
iirc, you, meaning white monster, do or did, turn the reg up on the airdog all the way to use the supply/return reg to set system pressure.
I tried turning the system pressure up but I developed a slight surge, higher fuel temps, and more noise from the lift pump. I've since turned it back down.
im not following why, on a 6.4, you have to regulate the supply and return. if your already regulateing the return, it seems kind of redundant, to also regulate the supply.
Regulate supply to dump excess fuel. Without a regulator the lift pump will keep pumping fuel and if the fuel can't flow through the pump fast enough pressure will rise, key on engine off and at idle are some examples of when excess fuel could be an issue. More testing to come before I have enough answers thou.
why does it matter what pump you have, to determine if you regulate just the return.
With an airdog you can set supply pressure with the internal regulator and then you can regulate the return on its own via a regulator. If you use an a1000 you don't have the internal regulator so it's possible you could need a second regulator. More testing on this to come.
im coming from a 7.3, which just requires a RR. everything betwKeen the pump and the return line, is X psi, which in our case, is about 60-65 psi.
does a 6.4 require 2 different pressures? one, say like 10 psi for the supply, and 3-4 for the return or something?
All we need is 10psi on the supply side just to keep the pump inlet flooded. Return pressure can be set at about 5psi but without testing I don't know if this is possible. The reason being that asking for only 5psi on the return might mean that only 5psi is maintained on the supply side. Hoping to get info on this soon.
what is so different about a 6.4, that your fuel systems are so....funky.
There not funky, there just new and were still learning all about them.
