oneturboforme
- Joined
- Sep 12, 2011
- Messages
- 1,040
- Reaction score
- 0
160 i thought
Yeah, I thought about it but I highly doubt it will ever come on. I know the fuel gets hot in the summer when towing. Plus I don't want to depend on the thermostat if it fails
Bringing this back because my cab is in the air. I'm probably going to do away with the fuel cooler completely. My question is more about the actuator cooler, wondering if anyone just teed it in with the cooling system? I see there was discussion about it, but has anyone done the deed with success?
corrected^Pulling the fuel cooler will result in vey high fuel temps unless you change the routing of the lines. Ppl have hit as high as 240 degrees on the fuel temp sensor.
I wouldnt delete the fuel cooler unless you are doing a low pressure fuel system..... At that point you could delete the fuel bowl, and instead of recirculating the heated fuel, you can just send it back to the tank and through a cooler on the frame rail. Really no point in deleting it with a stock system, seems more of a headache than anything.
**EDIT** perhaps I won't be testing without a fuel cooler^^I think the fuel cooler delete is a bad decision. No reason.
corrected^
I haven't bothered studying the stock system, but I know the Elite air dog upgrade kit returns the heated fuel to the tank. While technically the heated fuel (and previously cooled fuel in a system retaining the cooler) is directly connected to the supply system, it actually has to go in the opposite direction of flow past the regulator to be recycled instead of going to the tank. The problem some guys are having is that the air dog regulated pressure is lower than the regulator pressure on the air dog upgrade, not allowing the upgrade regulator to open, which leaves the hot fuel in a dead head system without a cooler in some cases, causing temps to skyrocket.
I'll be checking fuel temps on a truck without a fuel cooler, but with an AD-II, and airdog upgrade having properly set pressures so we can see where fuel temps end up. This will happen some time within this coming week if all goes well. Obviously it will still get hot if there's less than 1/4 tank, but this test will be with 1/2 tank plus. I expect that with the AD assist regulator opening, fuel temps will be manageable. If not, we'll consider some plumbing where either a fuel cooler goes back on, or return fuel is not regulated or both.
Pulling the fuel cooler will result in vey high fuel temps unless you change the routing of the lines. Ppl have hit as high as 220 degrees on the fuel temp sensor.
Wayne the only problem I have with your statement is that I can't regulate pressure at the a1000 so setting the regulator at the pressure of 10psi still results in very high fuel temps. The heat is transferring regardless of flow direction.
