tuning and Trans issue
higherlife
did your truck ever throw this code:
P0770 Shift Solenoid E circuit/solenoid failure
Triggers "Limp home mode," Transmission Warning light, and maybe Check Engine Light.
Stangr8cr
Is this dealer mod friendly? Curious if you took the truck as is or did you return to stock? Glad they got you figured out, hopefully that'll square you away.
Keith
Captaincworley
How long did it take you to return it back to stock?I dread if I ever have to return mine back to stock!
jcain
Thanks for manning up and taking responsibility for your choices... Oh wait..
higherlife
There is always one dumbass that has to chime in and try to start an argument.
I'm still curious what would cause a solenoid to fail. Is it a defect from Ford that 1 in 1000 trucks get or is it something to do with modifying these trucks being heavily controlled by electronic sensors, monitors and what not that's causing an issue. Definitely has me questioning the reliability.
spanky24365
massachusetts
I have read that any sort of debris ie. Metal shavings can cause the solenoid to fail.
Athens, IL
To lighten the mood, the E-clutch also known as the OD clutch is the weakes one in the trans. They are the weakest link in the whole trans from the factory. Early ones had 6 later has 7 we put 8 in... Also the 2015 has one less friction and steel in the forward and intermediate clutch packs as well. We have reverted back to the 2011-14 parts in order to get the higher clutch count we desire.
So in fact the 2015 6r140 so far is proving weaker by design.
Also, when the E-clutch is worn badly they will throw a code for the solenoid because the tcm does not have a way to differentiate a bad solenoid and physically worn clutches.
Here is a picture of what came out of the last 6r we did.
CATDiezel
Nice friction and steels morgan! Throttle much? Lol
Those clutches are the result of too many youtube video shoots!
Regarding going to the dealership... Ford denies so many warranties down in these parts I could care less if somebody puts a truck back to stock and takes it in. None of you truly care of about Fords bottom line. It's more of a jealousy factor in the fact they are getting it done. WARRANTY AWAY!! lol
Dzchey21
wyoming
wonder why they would go to a lower count clutch set? Must have something to do with shift quality or something...
I knew i didnt but a 15 for a reason LOL
Captaincworley
It would suck to go through all the trouble of putting it back to stock just to be denied because of the flash count lol.Hopefully it's just the solenoid and nothing else.
Athens, IL
Haha, I never expected it to last as long as it did honestly.
Yeah I would say the lack of failures in the 11-14's prompted them to try and save money..
For the op's sake I really do hope it's a solenoid.
spanky24365
massachusetts
Morgan so how will it be determined if it's the clutches and not the solenoid? Will the issues continue the same once the solenoid is replaced.
