MorganY
He's got a 2.3ms tune, with a more aggressive curve for the nitrous file :naughty:
Correct they are 100 over tips. Matt's still trying to figure out the best fueling curves for it. With it at 1.9ms of pw it won't light the turbo past 3 psi until 3rd gear with the way he has the fueling setup. That way I can street this turbo/fuel combo. If I remember correctly the 2.3ms tune had way more throttle response through every gear. When it hits 3rd gear on the 1.9 tune it wants to spool similar to my 66.
You might want to watch running that much timing with the power level you will be at unless you plan on replacing rods
And 2.2-2.3 is where that turbo will come to life but it is a slow spooler for sure
