Eric has mine set to 63 and od lockout in tow haul
So just curious what RPM that puts you at? I am guessing that really helps with the spool up
put a cherry bomb on it
^^ to the gasser comment...
Seabee what size single do you have, and fuel mods? Im assuming a 66-72 with stock or small fuel mods considering you are towing at all? I have a solid 900hp truck on any given day, and with the gates cranked shut and running the "tow" or "street" position on the minimaxx, would have no issue towing some pretty decent size loads. Some of your points are valid, again, comparing singles to stock location compounds or drop ins. Otherwise, normally compounds net you cooler egts then singles, with the same fueling. I guess you can argue less stress on the motor, down low, getting on it hard, because of the better spool up characteristics of a compound set up and the ability to create more power/torque/cylinder pressure down low. As far as back pressure, I actually have more boost then back pressure until about 25psi, then am 1:1 until 40psi. And again, the changing turbos thing without a doubt sucks on stock location chargers, especially if you aren't removing the cab, but if you have a custom compound set up, like mine, or one thats been added onto a single set up like yours, its not hard at all. The only thing that takes longer is the fact that there area few most things to loosen with the extra turbo, but none of it is hard to get to like the factory compounds.
I would rather own a stock charger than drive a lag shaft that spools late, **** is absolutely worthless IMO.
Bro, have a snickers.
LoL
Going back to towing. Some of you are saying it's hard to tow with a big single. Nice thing about a single is you can just swap it out for a smaller turbo and just tune the fuel back.
So...
Another questions.
Some have stated that they love the lower cruising egts? Other have stated that the cruising egts are not that bad... Which one is it? How do the egts compare?
The cruising and soft accelerating egt's is what turned me away... I was told that with a 366 it was nothing to break 1000° every time you accelerate. Also, cruising around at 3-5 psi is fine but come to a hill and the egt's climb fast. EGT's are lower at WOT though (over stock chargers, probably about the same with drop in turbos)So...
Another questions.
You tell me idk what I'm talking about but you're driving a non vgt single turbo truck with no egt gauge?You don't know what your talking about. Lol. Jk bud. I need to get my pyro fixed. I have the sensor but too lazy to replace.
But seriously, you should definitely get a gauge asap lol
I had one waiting for yore turbo to spool. King size to
So...
Another questions.
So...
Another questions.
