rusty1161
Have you checked your IPR harness? Mine looked like this and caused a no start.
I replaced it and all was good.
Rusty
You can see the bare copper at the connector.
Rusty
Rusty
I don't see bare wires but it's full of oil. Now the piece it's connected to seems loose. I can wiggle it back and forth I thought the sensor it self was loose but just the wire connector.
Replace it and make sure the tin nut in the IPR is snug. That tin nut can also be replaced with a 1/2-20 jam nut, loctite it in place.
Rusty
The plastic connector on the ipr will move a little bit, does not mean it's bad.
OK what about replacing the sensor also? The nut Is tight on there.
The IPR may be part of or your whole problem. At the age and mileage of these trucks, it will only hurt your pocketbook earlier than later to replace it, IMO. I'd switch to the 1/2-20 nut at the same time and eliminate that tin nut.
Rusty
Sunrise ford or riffraff diesel will have the best prices. But it's still not a cheap part. Not something you just want to throw at it and hope it works.
I just had to replace mine. I borrowed one that I knew was good and swapped it into my motor and it fired up. That's how I knew. If you've got oil in your icp sensor you'll need a new one of those as well.
Yep. You'll need a new or known good one also. And clean the wire connector with some sort of a contact cleaner to get the oil off.
I messaged you back. We have quite a few members down that way, post on here your location and see if anyone would be willing to volunteer some time or spare parts and help you out with a scanner or anything that's reads through the OBD port.
You need to get in touch with Danny (Imelmo). He is a good guy and is pretty close to you.
