Craig@MFI
- Joined
- May 18, 2011
- Messages
- 2,184
- Reaction score
- 0
By chance did the shop not install the wastegate valve seat?
Do you have atleast an airdog? Have you monitored your rail pressure? Wondering if its dipping down and not spooling it well...
He has stock fuel. Shouldn't be an issue.
I thought you needed atleast an airdog to run xrace even with stock turbos.... ideas
There was no separate wastegate valve seat with the kit. So no it was never installed.
Taking the gate off today when I get off work. I'll inspect it and see if the seat is on it or not. If it's not in there I guess I'll have to order one.
why wouldnt the valve seat be with the WG?
I have seen this before with Tial wastegates and HKS gates. It sucks but it happens. Quality control #12 did not look for it in the box but still pushed it through. I have also seen it with taco shells too. Open up the box and find them all crushed up!
Well i took the gate off the truck and tore it down to inspect it. Valve seat is on the gate. But when i was holding the gate in my hand i could hear something rolling around inside it, like bb's almost. I pulled the head apart and found the 4 set screws holding the valve to the diaphragm were just sitting in it... Put the set screws in and reinstalled gate, and put full boost to the top port.
