Breaking Habits
Big bitch but she moves lol![]()
Sent from my SCH-I545 using Tapatalk 2
When did craigles because phresh on twenny fo's?!
Well, we've had our kit in about the same state of completion for about a year now. We've been so busy with customer projects, orders, etc., that it has stayed on the back burner. That was until this past weekend. After 80000 miles of abuse, the shop truck popped the stock turbo, and it needs to be running again ASAP so the shop can keep functioning. It looks like our stuff will be tested and available sooner than later as another stock unit will not be going on. Here's a pic of some mock-up stuff back in February.
VGT and non-VGT options in various sizes will be available. They will be a drop-in setup capable of being added to for compounds as well. When the truck gets torn down, & turbo installed, we will likely be showing build pics in our vendor section. Stay tuned.
From driving that thing thats what it runs at lol driving its like 203
Thats crazy, figured it was from hot rodding it around. Mines never that high unless im pulling
Duramax VGT on a 6.7 powerstroke. Never would have thought of that one, but I guess the upipes(or whatever they are called on a 6.7) are a pretty close fit.
If H&S was spraying their 6.7 to 800+ horse, I would think that 600hp with a larger turbo and 55% of CP4 or dual fuelers should be safe, but everything is breakable.
ive seen 203 trans temps a bunch of times already, with a stock turbo. if you beat on it with converter unlocked you will see that.
I think it has to do more with the fabrication and the knowledge of airflow dynamics that helped produce the power it did over yours. Honestly I can't imagine any of your exhaust or intake side setup being beneficial to your kit. But that's neither here not there. MPD put down some good power today and I'd dare say that in a different truck with less rolling stock, you may even see more out of it. Either way, hats off to Craig
If you check the latest dyno Steve the trucks are both the same.
Woodboy posted it on .org
