TXlineman83
You don't need to delete your bowl for this setup. That I know for sure. My understanding of the stock system (with the FASS) is basically your FASS will supply the bowl at a constant pressure. At the bowl, there is a port to HPFP to supply fuel to it, but there is another spring loaded port that opens fully at 3 PSI that sends fuel back to the tank. There is also a port of incoming fuel from the cooler. Even at WOT, the FASS is supplying more than enough fuel to bowl and the bowl is just draining the excess fuel so that is why the pressure from the FASS will remain pretty constant.
Thank you.
"Opportunity is often overlooked because it is dressed in overalls and looks like work"
Thomas Edison.
